Danny DeVito
First, do these things ever run right ? Last three days after starting fine the idle is going up down for a bout five seconds then settles. Driving is normal. If i turn the engine off and restart immediately it still does it. After three days of this. Now a dirty scummy smell has started, comes in through air vents but i can smell it especially under the bonnet at the gearbox end of the engine. Could it be my injectors leaking again after only fitting new seals about three months ago ? The smell is much different though to when my injector was leaking. That smell was the carbon cut your throat smell. This is more rotten egg type, not that i ever smelled a rotten egg that i can remember, but i think it would smell like this if i had. My air-con doesn't work either never has since i got it. Any ideas ?? Thanks
