I had a full service last week, the car had a slight rough idle, I forgot to mention this when I left it in to main dealer for service, however I expected them to spot the fault and fix it, but the failed to detect it.
The idle has got a lot worse over the past week and I am concerned about bringing the car back to them as the will possibly start fixing it by elimination i.e. replace every thing one by one until the hit the fault. Very expensive. Any ideas?
Symptoms. (Engine normal working temperature)
I’m waiting for a kit to replace center bearing on the propeller shaft, could this have any relevance to the problem as the rough idle is only apparent when in gear, i.e. Drive - 2 –3 and Reverse
Dec
- Very slight rough idle over past few months, but not enough to bother me.
- Idle got a lot worse since service. Fluctuates between 500-800rpm, should be about 750rpm
- Rough idle in Drive - 2 –3 and Reverse
- Changing to Neutral or Park eliminates the problem; the revs increase slightly to a steady 900rpm approx.
- Excellent starting, car drives perfect
Dec
