EVL124
- Jun 27, 2010
- Location
- Auckland, New Zealand
- 1993 320CE with Brabus and AMG goodies
OK, so my idle is still off, when car is cold its perfect, as it warms up it gets a bit lumpy - mostly smooth with a slight miss, also when re-starting car when warm revs fluctuate quite badly for a couple of minutes before settling back to the almost smooth but slight misfire every few seconds. Here is what has been replaced/tested - really running out of things to do now.
Wiring loom
All 3 coils
3 plug supressors and HT leads
Spark plugs
MAF
02 sensor
Throttle body wiring rebuilt - also other known OK throttles tested to make sure it wasn't internals
Known good OVP relay tested
Known good crank sensor tested
Known good ECU tested
Known good coolant temp sensor tested
Compression check has been done, one pot is about a bar lower, but nothing to be too concerned about.
What else is there that it could actually be??? This is driving me insane!
Wiring loom
All 3 coils
Spark plugs
MAF
02 sensor
