Owen
Went to do an oil change on my 190E, all ready to go, got on the ground socket in hand only to find some fool had put the sump nut on with such force the head of the nut was a cylinder and same fool did so without putting a copper washer behind the nut - end of rant.
Tryed everything to shift it with no luck. Then while doing some on-line reasearch into the problem I found this:
http://www.irwin.com/irwin/consumer...WNUP000160¤tType=BM1000005&search=false
Not the cheapest solution (£22 for the set) in the world but it worked first try and is one of those tools I know will save the day again. :bannana:
