rubber brake pipe W210 E300TD
It is 25% from the code here but on the website it was 30%. I know as I have just bought new front discs and front and rear pads and got £50 discount :)
Nope... not 30% here :(
20.70 for a peice of rubber... I wonder what MB is actually charging for it?
you can see if the 124 estate has a decent pipe you can steal off it if you want
I am looking at the website right now. In the centre is a series of different offers and it is showing 30% off braking and filters. Use promo code 30NOW
Not sure if it applies to all brake components but if not you can still get the 25% and brake hoses are fairly cheap anyway :thumb:
not working, thank you tho :
One or more of the products you have choosen are not included in the promotion code you have used and will therefore not benefit from the promotion code. However you will still be able to progress with your order.
Well you can still get the 25% off and a brake hose is more than just a piece of rubber, it has to cope with flexing, twisitng and high pressures for years at a time whilst exposed to extremes of temperature etc :)
Indeed, its a nice analogy :)
Thank you DSM ;)
and this is true, this is not been sarcastic, Its indeed a nice analogy.
Olivier
Hi Bren,
I've emailed you before starting this but got no replies :(
Unfortunatly I got one from SRS for 7 quid too, I would have prefered to keep going with you tho .
Olivier
