Hi folks I wonder if one of the members are able to help please. I've got a 2009 a class classic and I am displaying a runflat tire indicator despite repeatedly resetting .my tires have all checked okay but I have recently had one new tyre on the nearside with a half worn one on the other side I am aware that it uses the ABS and the tire circumference to determine whether you have a flat tyre ,I am wondering if this is what is constantly setting it off I have also just jetwashed all the inside of my wheel wells and I wondering if the water has affected the sensors ?.
my question is ,where are these particular sensors that determine if you have a flat tire and is it possible to clean or check for a loose wire if it has been struck by high-pressure water for instance .I hope you are able to help thanks very much
