running a amp from the battery through the firewall
soundcriminals
220 te
Hi guys I just got a 1994 220 te estate and was wondering if anyone had any idear how to get the 12v feed from the battery to the amp that I am installing in the boot, through the firewall. I cannot find a way through
Iḿ not sure on your particular model but most cars will have wires going at some point. Also some cars will have spare blank grommets and you can run a power feed through those.
that is was what I was hoping but I could not find any and don't really want to drill a hole but I guess I will if I have to.
There will be a way into the cabin, Via blank grommets, either adjacent to the battery area, or in the side of the fuse box.
Just make sure to fuse it in the engine compartment and use the appropriate gauge of wire fit to take the load/current.
