froggiegit
- Sep 10, 2015
- Mercedes C200k
Hi, Bought a 2001 (W203) C200K estate 2 years ago and very pleased with it. Recently it runs great from cold but seems a bit more hesitant when up to temperature. Had some codes came up from time to time - before and after the problem. Cleaned the MAF sensor with contact cleaner and the switch/air tubes leadin from/to it also the cam sensor and air sensor switches. No longer get the codes. Also car doesn't always kick down from 3rd to second so had the transmission fluid and filter changed. Still get the problem. It's only intermittent, sometimes it runs perfectly other times its a pain.Could this be fuel filter related as when cold it ir perfect (maybe due to the richer mixture). Plugs have done about 20K miles - Mercedes recommend change at 50K ish.
Any advice much appreciated
