captainb
I have a problem with the rusty plastic window pillar covers. I guess they must be steel with a plastic coating on them.
The gaskets around them seemed to be failing which is probably the cause of it.
Not really sure what to do with them or how to remove. Probably need to replace them but I couldn't be confident on the part number from the online epc
I'm sure this must be a common problem.
Has anyone repaired them before ?
How do you remove and install ?
What to do about gasket seals ?
Attached a few pics for clarity.
