RWT - Rear-end door control module
Borris1954
South Bucks
S204 C 250 CGI BlueEFFICIENCY, R170 SLK 230, B 180d AMG Line
DAS reports the following as stored fault code 9000 on my 2006 S211
Component A72 (Rear door locking unit) is faulty or the line to the
component has a short circuit or open circuit. ( Coupling motor :
Short or open circuit when locking or unlocking )
If I clear the fault it pops back fairly quickly but there are no apparent problems with the Rear Door locking or unlocking whatsoever and I wouldn't know there was an issue unless DAS told me.
Can anybody shed any light on the likely cause other than that I should probably change the module at some point fairly soon?
