S Class W221 error code list
Steveamg
BMW M3
Any one have or know where I can get a list of error codes for the W221 series?
I've had a look on line but could not locate anything.
Many thanks
Hope I am not to late to help.
PART 1:
Mercedes Benz Common Fault codes
Mercedes Fault codes can be a pain especially the body and chassis control*
codes.*
Here is a detailed list of them:
Circuit Malfunction*
P0466 Purge Flow*Sensor*Circuit Range/Performance*
P0467 Purge Flow*Sensor*Circuit Low Input*
P0468 Purge Flow Sensor Circuit High Input*
P0469 Purge Flow Sensor Circuit Intermittent*
P0470*Exhaust*Pressure Sensor Malfunction*
P0471*Exhaust*Pressure Sensor Range/Performance*
P0472*Exhaust*Pressure Sensor Low
P0473*Exhaust*Pressure Sensor High
P0474*Exhaust*Pressure Sensor Intermittent*
P0475*Exhaust*Pressure Control Valve Malfunction*
P0476*Exhaust*Pressure Control Valve Range/Performance*
P0477*Exhaust*Pressure Control Valve Low
P0478*Exhaust*Pressure Control Valve High
P0479*Exhaust*Pressure Control Valve Intermittent*
P0480*Cooling Fan*1 Control Circuit Malfunction
P0481*Cooling Fan*2 Control Circuit Malfunction
P0482*Cooling*Fan*3 Control Circuit Malfunction
P0483*Cooling*Fan*Rationality Check Malfunction
P0484*Cooling*Fan*Circuit Over Current
P0485*Cooling*Fan*Power/Ground Circuit Malfunction
P0500*Vehicle*Speed*Sensor*Malfunction*
P0501*Vehicle*Speed*Sensor*Range/Performance*
P0502*Vehicle*Speed*Sensor*Low Input
P0503*Vehicle*Speed*Sensor*Intermittent/Erratic/High*
P0505 Idle Control System Malfunction*
P0506 Idle Control*System*RPM Lower Than Expected*
P0507 Idle Control*System*RPM Higher Than Expected*
P0510 Closed Throttle Position Switch Malfunction*
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521 Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522 Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523 Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530 A/C Refrigerant Pressure Sensor Circuit Malfunction*
P0531 A/C Refrigerant Pressure Sensor Circuit Range/Performance*
P0532 A/C Refrigerant Pressure Sensor Circuit Low Input*
P0533 A/C Refrigerant Pressure Sensor Circuit High Input*
P0534*Air*Conditioner*Refrigerant Charge Loss*
P0550*Power*Steering*Pressure Sensor Circuit Malfunction*
P0551*Power Steering*Pressure Sensor Circuit Range/Performance*
P0552*Power Steering*Pressure Sensor Circuit Low Input*
P0553*Power Steering*Pressure Sensor Circuit High Input*
P0554*Power Steering*Pressure Sensor Circuit Intermittent*
P0560 System Voltage Malfunction*
P0561 System Voltage Unstable*
P0562 System Voltage Low*
P0563 System Voltage High*
P0565 Cruise Control On Signal Malfunction*
P0566 Cruise Control Off Signal Malfunction*
P0567 Cruise Control Resume Signal Malfunction*
P0568*Cruise Control*Set Signal Malfunction*
P0569*Cruise Control*Coast Signal Malfunction*
P0570 Cruise Control Accel Signal Malfunction*
P0571 Cruise Control/Brake Switch A Circuit Malfunction*
P0572 Cruise Control/Brake Switch A Circuit Low*
P0573 Cruise Control/Brake Switch A Circuit High*
P0574 Cruise Control Related Malfunction
P0575 Cruise Control Related Malfunction
P0576 Cruise Control Related Malfunction
P0578 Cruise Control Related Malfunction
P0579 Cruise Control Related Malfunction
P0580 Cruise Control Related Malfunction
P0600 Serial Communication Link Malfunction*
P0601 Internal Control Module Memory Check Sum Error*
P0602 Control Module Programming Error*
P0603 Internal Control Module Keep Alive Memory (KAM) Error*
P0604 Internal Control Module Random Access Memory (RAM) Error*
P0605 Internal Control Module Read Only Memory (ROM) Error*
P0606 PCM Processor Fault*
P0608 Control Module VSS Output "A" Malfunction
P0609 Control Module VSS Output "B" Malfunction
P0620 Generator Control Circuit Malfunction
P0621 Generator Lamp "L" Control Circuit Malfunction
P0622 Generator Field "F"*Control*Circuit Malfunction
P0650 Malfunction*Indicator*Lamp (MIL) Control Circuit Malfunction
P0654 Engine RPM Output Circuit Malfunction
P0655 Engine Hot Lamp Output Control Circuit Malfucntion
P0656*Fuel*Level Output Circuit Malfunction
P0700*Transmission*Control System Malfunction
P0701 Transmission Control System Range/Performance
P0702 Transmission Control System Electrical
P0703 Torque Converter/Brake Switch B Circuit Malfunction
P0704 Clutch Switch Input Circuit Malfunction
P0705*Transmission*Range*Sensor*Circuit malfunction (PRNDL Input)
P0706*Transmission*Range*Sensor*Circuit Range/Performance
P0707*Transmission*Range*Sensor*Circuit Low Input
P0708*Transmission*Range*Sensor*Circuit High Input
P0709*Transmission*Range*Sensor*Circuit Intermittent
P0710*Transmission*Fluid*Temperature Sensor Circuit Malfunction
P0711*Transmission*Fluid*Temperature Sensor Circuit Range/Performance
P0712*Transmission*Fluid*Temperature Sensor Circuit Low Input*
P0713*Transmission*Fluid*Temperature Sensor Circuit High Input*
P0714*Transmission*Fluid*Temperature Sensor Circuit Intermittent
P0715 Input/Turbine*Speed*Sensor*Circuit Malfunction
P0716 Input/Turbine*Speed*Sensor*Circuit Range/Performance
P0717 Input/Turbine*Speed*Sensor*Circuit No Signal
P0718 Input/Turbine*Speed*Sensor*Circuit Intermittent
P0719 Torque Converter/Brake Switch B Circuit Low
P0720*Output*Speed*Sensor*Circuit Malfunction
P0721*Output*Speed*Sensor*Range/Performance
P0722*Output*Speed*Sensor*No Signal
P0723*Output*Speed*Sensor*Intermittent
P0724 Torque Converter/Brake Switch B Circuit High
P0725 Engine Speed input Circuit Malfunction
P0726 Engine Speed Input Circuit Range/Performance
P0727 Engine Speed Input Circuit No Signal
P0728 Engine Speed Input Circuit Intermittent
P0730 Incorrect Gear Ratio
P0731 Gear 1 Incorrect ratio
P0732 Gear 2 Incorrect ratio
P0733 Gear 3 Incorrect ratio
P0734 Gear 4 Incorrect ratio
P0735 Gear 5 Incorrect ratio
P0736 Reverse incorrect gear ratio
P0740*Torque*Converter*Clutch Circuit Malfuction
P0741*Torque*Converter*Clutch Circuit Performance or Stuck Off
P0742*Torque*Converter*Clutch Circuit Stuck On
P0743*Torque*Converter*Clutch Circuit Electrical
P0744*Torque*Converter*Clutch Circuit Intermittent
P0745 Pressure Control*Solenoid*Malfunction
P0746*Pressure*Control*Solenoid*Performance or Stuck Off
P0747*Pressure*Control*Solenoid*Stuck On
P0748*Pressure*Control*Solenoid*Electrical
P0749*Pressure*Control*Solenoid*Intermittent
Part 2:
P0750 Shift*Solenoid*A Malfunction
P0751 Shift*Solenoid*A Performance or Stuck Off
P0752 Shift*Solenoid*A Stuck On
P0753 Shift*Solenoid*A Electrical
P0754 Shift*Solenoid*A Intermittent
P0755 Shift*Solenoid*B Malfunction
P0756 Shift*Solenoid*B Performance or Stuck Off
P0757 Shift*Solenoid*B Stuck On
P0758 Shift*Solenoid*B Electrical
P0759 Shift*Solenoid*B Intermittent
P0760 Shift*Solenoid*C Malfunction
P0761 Shift*Solenoid*C Performance or Stuck Off
P0762 Shift*Solenoid*C Stuck On
P0763 Shift*Solenoid*C Electrical
P0764 Shift*Solenoid*C Intermittent
P0765 Shift*Solenoid*D Malfunction
P0766 Shift*Solenoid*D Performance or Stuck Off
P0767 Shift*Solenoid*D Stuck On
P0768 Shift*Solenoid*D Electrical
P0769 Shift*Solenoid*D Intermittent
P0770 Shift*Solenoid*E Malfunction
P0771 Shift*Solenoid*E Performance or Stuck Off
P0772 Shift*Solenoid*E Stuck On
P0773 Shift*Solenoid*E Electrical
P0774 Shift*Solenoid*E Intermittent
P0780 Shift Malfunction
P0781 1-2 Shift Malfunction
P0782 2-3 Shift Malfunction
P0783 3-4 Shift Malfunction
P0784 4-5 Shift Malfunction
P0785 Shift/Timing*Solenoid*Malfunction
P0786 Shift/Timing*Solenoid*Range/Performance
P0787 Shift/Timing*Solenoid*Low
P0788 Shift/Timing*Solenoid*High
P0789 Shift/Timing*Solenoid*Intermittent
P0790 Normal/Performance Switch Circuit Malfunction
P0801 Reverse Inhibit*Control*Circuit Malfunction
P0803 1-4 Upshift (Skip Shift)*Solenoid*Control Circuit Malfunction
P0804 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P0805 Clutch Position*Sensor*Circuit Malfunction
P0806 Clutch Position*Sensor*Circuit Range/Performance
P0807 Clutch Position*Sensor*Circuit Low
P0808 Clutch Position*Sensor*Circuit High
P0809 Clutch Position Sensor Circuit Intermittent Ckt
P0810 Clutch Position Control Malfunction
P0811 Clutch Slippage Excessive
P0812 Reverse Input Circuit Malfunction
P0813 Reverse Output Circuit Malfunction
P0814 Trans Range Display Circuit Malfunction*
P0815 Upshift Switch Circuit Malfunction
*P0816 Downshift Switch Circuit Malfunction*
P0817 Starter Disable Circuit*
P0818 Driveline Disconn. Switch Input
P0820 Gear Lever X-Y Sensor Circuit*
P0821 Gear Lever X Sensor Circuit*
P0822 Gear Lever Y Sensor Circuit*
P0823 Gear Lever X Sensor Circuit Intermittent Ckt
P0824 Gear Lever Y Sensor Circuit Intermittent Ckt
P0830 Clutch Position Switch A Circuit Malfunction
P0831 Clutch Position Switch A Circuit Low
P0832 Clutch Position Switch A Circuit High
P0833 Clutch Position Switch B Circuit Malfunction
P0834 Clutch Position Switch B Circuit Low
P0835*Clutch*Position Switch B Circuit High
P0836 4*Wheel*Drive Switch Circuit Malfunction
P0837 4*Wheel*Drive Switch CKT Range/Perf
P0838 4 Wheel Drive Switch Circuit Low*
P0839 4 Wheel Drive Switch Circuit High*
P0840 Trans Fluid Press Sensor/Switch A Circuit Malfunction*
P0841 Trans Fluid Press Sensor/Switch A CKT Range/Perf
P0842 Trans Fluid Press Sensor/Switch A Circuit Low
P0843 Trans Fluid Press Sensor/Switch A Circuit High
P0844 Trans Fluid Press Sensor/Switch A CKT Intermittent
P0845 Trans Fluid Press Sensor/Switch B Circuit Malfunction
P0846 Trans Fluid Press Sensor/Switch B CKT Range/Perf
P0847 Trans Fluid Press Sensor/Switch B Circuit Low
P0848 Trans Fluid Press Sensor/Switch B Circuit High
P0849 Trans Fluid Press Sensor/Switch B CKT Intermittent
P1000 Electronic Gear Selector Module: Defective N15/5*
P1228 yet unknown code on 1997 C 220 CDI*
P1386 knock control*
P1570 Intermittant No-Start Immobiliser Module
P1581 ?
P1747 Electronic Gear Selector Module: Defective Interaction of CAN*
with control unit A1(instrument*cluster)
P1750 Electronic Gear Selector Module: Very low control unit supply*
voltage
P1832 Electronic Gear Selector Module: SHORT in circuit N15/5 output*
stage
P1910 Electronic Gear Selector Module: Control Unit over voltage
P1912 Electronic Gear Selector Module: Weak touch push button voltage
P2000 NOx Trap Efficiency Below Threshold (Bank 1)
P2001 NOx Trap*Efficiency*Below Threshold (Bank 2)
P2003 Particulate Trap Efficiency Below Threshold (Bank 1)
P2004 Particulate Trap Efficiency Below Threshold (Bank 2)
P2031*Exhaust*Gas Temperature Sensor Circuit (Bank 1 Sensor 2)
P2032*Exhaust*Gas Temperature Sensor Circuit Low (Bank 1 Sensor 2)
P2033*Exhaust*Gas Temperature Sensor Circuit High (Bank 1 Sensor 2)
P2080*Exhaust*Gas Temperature Sensor Circuit Range/Performance (Bank 1*
Sensor 1)
P2081*Exhaust*Gas Temperature Sensor Circuit intermittant (Bank 1 Sensor*
1)*
P2100*Throttle*Actuator*Control Motor Circuit/Open
P2101*Throttle*Actuator*Control Motor Circuit Range/Performance
P2208 transmission: The speed of Y3/6n2 to Y3/6n3 is excessive
Body
B1000 HRA*Headlamp*range adjustment:*Supply*voltage*of the control unit is*
too low (undervoltage)
B1004 LCP Lower Control Panel: Control unit does not match vehicle type
B1056 Automatic Air Conditioning: Problem in CAN communication with*
control unit DCM-RL
B1201 Electric seat adjustment front left: Hall*sensor*front height*
M27m3
B1213 If*seat*memory installed: ext left*rearview*mirror*voltage faulty
B1214 If seat memory installed: ext right*rearview*mirror*voltage faulty
B1226 In-car temperature sensor (B10/4)
B1227 Outside temperature indicator temp sensor (014)
B1128*Heater*core*temperature (B10/1)
B1229*Heater*core*temperature (B10/1)
B1230 Evaporator temperature sensor (B10/6)
B1231 ECT sensor (B11/4)
B1232 Refrigerant pressure sensor (B12)
B1233 Refrigerant temperature sensor (B12/1)
B1234 Sun sensor (B32)
B1235 Emissions sensor (B31)
B1241 Refrigerant Fill
B1246 PTS Parktronic: A42b1 (left outer sensor, front bumper) The plug*
connection has poor contact or is loose, or the sensor or cable is faulty
B1310 Left/Window airbag sensor is defective
B1315 Problem in Front passenger child seat recognition
B1416 Coolant circulation pump (M13)
B1417 Duovalve (Y21y1), left
B1418 Duovalve (Y21y2), right
B1419 Electromagnetic clutch (A9k1)
B1420 Idle speed increase
B1421 Pulse module (N05)
B1422 Series interface (K1) connection to*instrument*cluster*(A1)
B1423 Switchover valve block (Y11)
B1424 Activated charcoal filler actuator (A32m2) open
B1425 Activated charcoal filler actuator (A32m2) closed
B1432 Non-USA DTC
B1459 Series interface (K2) connection to*instrument*cluster*(A1)
B1462 Wide open throttle (WOT) position signal diesel engines
B1476 Airbag malfunction indicator and*warning*lamp*is defective
B1481 HRA: Part E2m1 (Right headlamp range adjustment motor) has short to*
ground
B1489 HRA: Part E2m1 (Right headlamp range adjustment motor) has open or*
short to positive
B1492 HRA: Part E1m1 (Left headlamp range adjustement motor) has*
short to positive
B1617 Part E19/1 (Left*license*plate*lamp) is defective
B1618 Part E19/2 (Right*license*plate*lamp) is defective
B1628 Part E2e5 (Turn signal lamp) in module E2 (Right*front*headlamp*
unit) is defective.
B1703 Intermittant No Start in AAM Immobiliser Module
B1729 PSE Pneumatic*system*doorlock Control Module A37
B1736 Navigation system's CD Player: Check General CD, Check CD data*
block, Flimsy CD data*
B1768 Faulty open data flap limit switch (0025) Front flap
B1773 HRA: Zero position programming has not yet been carried out or is*
not possible
B1850 Electric seat adjustment front right: CAN communication interrupted*
with DCM
PART 3:
Chassis
C1000 Traction System Control Module*
C1010*Battery*Voltage Low*
C1011 ASR/ETS/ESP Circuit Open or Shorted*
C1012*Battery*Voltage High*
C1020 CAN Communication Fault*
C1021 CAN Communication With EA/CC/ISC Control Module Interrupted*
C1024 CAN Communication With*Engine*Control*Module*Interrupted*
C1025 CAN Communication BAS communication with ESP control unit faulty
C1100 Left Front Axle VSS Circuit Fault*
C1101 Right Front Axle VSS Circuit Fault*
C1102 ETS/ASR, ABS Left Axle VSS Circuit Fault*
C1103 Right Rear Axle VSS Circuit Fault*
C1121 AIRmatic: fault in component B24/3 (acceler. sensor)
C1122 AIRmatic: fault in component B24/4 (acceler. sensor)
C1123 AIRmatic: fault in component B24/6 (acceler. sensor)
C1132 AIRmatic: fault in component*B22/8*(level sensor)
C1133 AIRmatic: fault in component*B22/9*(level sensor)
C1135 AIRmatic: fault in component B22/3 (level sensor)
C1140 BAS light, play in*steering*column causes*steering*angle*sensor*to*
lose memory(?)
C1142 ABS Lateral Acceleration Sensor Open/Shorted*
C1144 AIRmatic: fault in component B7 (pressure sensor)
C1200*Stop*Light*Switch*Open/Shorted/Implausible*
C1300 Left Front Axle*Solenoid*Valve (Hold) (A7/3y6) Open/Shorted*
C1303 Right Front Axle*Solenoid*Valve (Hold) Open/Shorted*
C1311 Switchover*Solenoid*Valve (Release) Open/Shorted*
C1312 Master Cylinder Switchover Valve*
C1401 High*Pressure*Return Pump Circuit Open/Shorted; Will Not Shut Off*
C1501 SPS P-Valve*
C1504 BAS light, play in*steering*column causes*steering*angle sensor*to*
lose memory(?)
C1512 Brakes Overheated*
C1600 Temperature After*Engine*Is Turned Off*
New Systems
U0001 High Speed CAN Communication Bus
U0002 High Speed CAN Communication Bus Performance
U0003 High Speed CAN Communication Bus (+) open
U0004 High Speed CAN Communication Bus (+) low
U0005 High Speed CAN Communication Bus (+) high
U0006 High Speed CAN Communication Bus (-) open
U0007 High Speed CAN Communication Bus (-) low
U0008 High Speed CAN Communication Bus (-) high
U0009 High Speed CAN Communication Bus (-) shorted to Bus (+)*
U0010 Medium Speed CAN Communication Bus
U0011 Medium Speed CAN Communication Bus Performance
U0012 Medium Speed CAN Communication Bus (+) open
U0013 Medium Speed CAN Communication Bus (+) low
U0014 Medium Speed CAN Communication Bus (+) high
U0015 Medium Speed CAN Communication Bus (-) open
U0016 Medium Speed CAN Communication Bus (-) low
U0017 Medium Speed CAN Communication Bus (-) high
U0018 Medium Speed CAN Communication Bus (-) shorted to Bus (+)*
U0019 Low Speed CAN Communication Bus
U0020 Low Speed CAN Communication Bus Performance
U0021 Low Speed CAN Communication Bus (+) open
U0022 Low Speed CAN Communication Bus (+) low
U0023 Low Speed CAN Communication Bus (+) high
U0024 Low Speed CAN Communication Bus (-) open
U0025 Low Speed CAN Communication Bus (-) low
U0026 Low Speed CAN Communication Bus (-) high
U0027 Low Speed CAN Communication Bus (-) shorted to Bus (+)
U0028 Vehicle Communication Bus A
U0029 Vehicle Communication Bus A Performance
U0030 Vehicle Communication Bus A (+) open
U0031 Vehicle Communication Bus A (+) low
U0032 Vehicle Communication Bus A (+) high
U0033 Vehicle Communication Bus A (-) open
U0034 Vehicle Communication Bus A (-) low
U0035 Vehicle Communication Bus A (-) high
U0036 Vehicle Communication Bus A (-) shorted to Bus (+)
U0037 Vehicle Communication Bus B
U0038 Vehicle Communication Bus B Performance
U0039 Vehicle Communication Bus B (+) open
U0040 Vehicle Communication Bus B (+) low
U0041 Vehicle Communication Bus B (+) high
U0042 Vehicle Communication Bus B (-) open
U0043 Vehicle Communication Bus B (-) low
U0044 Vehicle Communication Bus B (-) high
U0045 Vehicle Communication Bus B (-) shorted to Bus (+)
U0046 Vehicle Communication Bus C
U0047 Vehicle Communication Bus C Performance
U0048 Vehicle Communication Bus C (+) open
U0049 Vehicle Communication Bus C (+) low
U0050 Vehicle Communication Bus C (+) high
U0051 Vehicle Communication Bus C (-) open
U0052 Vehicle Communication Bus C (-) low
U0053 Vehicle Communication Bus C (-) high
U0054 Vehicle Communication Bus C (-) shorted to Bus (+)
U0055 Vehicle Communication Bus D
U0056 Vehicle Communication Bus D Performance
U0057 Vehicle Communication Bus D (+) open
U0058 Vehicle Communication Bus D (+) low
U0059 Vehicle Communication Bus D (+) high
U0060 Vehicle Communication Bus D (-) open
U0061 Vehicle Communication Bus D (-) low
U0062 Vehicle Communication Bus D (-) high
U0063 Vehicle Communication Bus D (-) shorted to Bus (+)
U0064 Vehicle Communication Bus E
U0065 Vehicle Communication Bus E Performance
U0066 Vehicle Communication Bus E (+) open
U0067 Vehicle Communication Bus E (+) low
U0068 Vehicle Communication Bus E (+) high
U0069 Vehicle Communication Bus E (-) open
U0070 Vehicle Communication Bus E (-) low
U0071 Vehicle Communication Bus E (-) high
U0072 Vehicle Communication Bus E (-) shorted to Bus (+)
U0073 Control Module Communications Bus Off
U0100 Lost Communication with ECM/PCM A
U0101 Lost Communication with TCM
U0102 Lost Communication with Transfer Case Control Module
U0103 Lost Communication with Gear Shift Module
U0104 Lost Communication with Cruise Control Module
U0105 Lost Communication with Fuel Injector Control Module
U0192 Lost Communication with Television
U0197 Lost Communication with*Telephone*Control*Module
U0198 Lost Communication with Telematic Control Module
U0222 Lost Communication with*Door*Window*Motor*A
U0235 Lost Communications with Cruise Control Front Distance Range Sensor
U0301 Software Incompatibility with ECM/PCM
U0302 Software Incompatibility with TCM (Transmission*Control*Module)
U0303 Software Incompatibility with Transfer Case Control Module
U0321 Software Incompatibility with Ride Level Control Module
U0326 Software Incompatibility with Vehicle Immobilizer Control Module
U0327 Software Incompatibility with Vehicle Security Control Module
Mercedes Fault code Library
Mercedes new Bosch drive-by-wire*throttle*body*failing
Mercedes SL / S*Class*'90s*Instrument*Cluster*problems*
Mercedes Smart car*steering*rack Failure
Mercedes Earlier C*Class*instrument cluster*gauge problems
Mercedes hydraulic roof pump on newer CL SL CLK SLK Class failing
Mercedes Sensotronic SBC system failing
Mercedes central locking vacuum pump
Mercedes SLK*instrument*cluster*/ panel / dashboard failing
Mercedes S Class*instrument*cluster*/ panel / dash failing
Mercedes C and E Class dashboards failing
Mercedes*Throttle*Body
Mercedes A Class electric hydraulic*power steering*failing
Mercedes A Class combined air mass meter and ECU
Merecedes A*Class*air*flow*meters failing*
Mercedes 111 16v*engine*throttle*body*failing
Mercedes C and E Class*ABS pump*failing*
Mercedes C/E/S Class, CLK/SLK*throttle*bodies*failing
Mercedes*CL*and SL Class soft top convertible roof controllers failing*
Mercedes 280/300/350 ECU*
Mercedes 300/AMG 300 ECU*
Mercedes CLK 320, SL 280, SL 320 ECU*
Mercedes VDO ecu systems being damaged by harness overheating
Mercedes Seimens and Bosch*ignition*modules*failing
Mercedes E Class ABS ECU fault codes*
*Common Ignition ECU failures*
*C Class & E Class Cats rattling from 93 on
johncook109 are you stalking Steveamg's old posts?
Sorry, nothing to do while getting over Opp so I search for anyone with the same car as mine. I must stop it.
