jcfixerofshiz
Hi all.
Bought a grown up car a few months back S204 350cdi auto. All been going well and going through all the little things to make sure it'll go on for years to come.
Had the transmission oil and filters changed and plugged into the stars scanner to check for fault code (coolant temp switch over valve. New fitted)
Since then it occasionally goes into limp mode (I assume) won't go above 4th gear, even if I change it to manual. Holds the gears till 3k before changing. No performance.
Engine can be either cold (work commute) or hot after along drive. Doesn't seem to match up to a re-gen cycle either as the idle is still at 600, and stop/start is still working
Turn the engine off and back on, and your good to go till it happens again.
Had it scanned again, nothing.
Anybody come across this one? TIA
