Hi Everyone,
I recently purchased a 2011 C-Class S204 and I have noticed that it suffers from a very strange clutch issue.
The clutch pedal is very stiff/hard during normal driving and when i have been driving for long periods on the motorway (usually 30+ mins in 5th or 6th gear) i have found that when i come off onto the slipway and depress the clutch pedal that it is sometimes sticking to the floor. When this happens changing gear becomes very difficult but not impossible, however i can quite easily hook my foot under the pedal and lift it back up to its normal position which solves the issue and doesn't happen again until another long period of driving.
Currently i have replaced the slave cylinder and have also bled the clutch fluid but this has not fixed the issue.
Any thought on what could be causing this combination of issues?
My next port of call was maybe Master cylinder, beyond that maybe release bearing/clutch fork and lastly clutch/flywheel change
Thanks,
Josh - JET1997
Thanks,
Josh - JET1997
