LawrenceMB
- Apr 23, 2012
- Location
- now in Auckland, NZ
- Work wagon: 1998 S210 E320 . Holidays: 2000 S210 E55. Sunny days! 2000 CLK430
Hiya, I've picked up a facelift 210 E55 estate which I LOVE and want to change the diff oil as part of the full service I'm giving it. I've checked WIS and all the previous posts and forums but are even more confused with the conflicting info. Does anyone know please if the diff should take the 75W-85 as is ok for most MB cars, or the 75W-140 which WIS says should be used for the 211 with 'AMG locking diff'? I can't find anything specific to the 210 E55 on WIS. I've tried to attach some photos of the diff and markings but files are too large? Anyway the diff has the casing part number A210 350 01 05. The diff fluid capacity seems to be 1.6litres. The rear plate/cover seems to have 9 or 10 bolts? I can't see the very top of the diff, but if the rear plate and it's bolts are symethrical then it has 10 bolts. The breather is at the back top on the RH side. I tried to see if it was a LSD diff by jacking both rear wheels off the ground and turning either back wheel while gearbox in neutral, and the opposite wheel does turn the other direction - although if I turn it slowely enough the other wheel will remain stationary. I can't see anything that says AMG on the diff anywhere - does that mean it is not an 'AMG locking diff'? and so is ok to use the more general 75w-85? (which I have a couple of bottles of already) or is the 75w-140 the right one to use. Please help! Thanks
