philg1981
- Feb 21, 2015
- Location
- Costa del Northern Ireland
- w140 s500 - got hydraulics fitted! daily - s210 320 cdi mapped and low(ish)
2002 s210 320cdi. Started getting a real bad knock especially at lower speeds at n/s/r. Had a quick look at lunch and the shock unit dosent seem to have much pressure ie hand in and give it abit of a wiggle. Other side was tight. Could this be low oil pressure due to u/s sphere? No obvious leaks. And where abouts under the bonnet is the reservoir for the sls? So can check level.
Take it if was sphere it's best to replace the pair?
Tganks for any info/help
