Hi all
Purchased an e270 cdi estate which is stuck in limp mode, showing abs/esp fault in cluster and will drive but only in 1 gear.
I checked fault codes with my launch x431 diagun and had the following:
C1439 & c1479 : left & right rear speed sensors. Had the same in esp & transmission module.
I changed the rear left sensor and still the same
I've monitored the values of each wheel and no values show for the rear
Reckon it could be the reluctor rings?
