s211 airmatic relay
DavidL
s203 C55, x218 CLS63
I've done a bit of a search but I'm not exactly sure still. Where is this?
In the bonnet fuse box but which one?
Had the second instance (in 6 months) of what I think is the airmatic pump running after the ignition is off. Took the car for a quick spin but still the same but an hours run home and its fine. Just before I reached home I did get the up arrow malfunction but I'd been going an hour by then.
I get this very occasionally - once every 2 months or so and it tends to be when I accelerate from a slow moving bit on a steep uphil. Same today.
I've had the pump tested and all was well.
I wonder if the relay was stuck on? I gather this relay can be a bit iffy.
So first thing is find it!
at the very back, nearest the windscreen, on its own little clip thing. outside the main box
normal 4 pin relay.
Are main dealers the only option for new relays? I can't find anyone selling new relays other than the dealers.
Just to update this:
Fuse box behind steering wheel under the bonnet, position S
Part nos
old 0025422319
new 0025427619
£10.77 from MB Salisbury.
