Hi all,
I've a 2003 E220 CDI Estate. I replaced the main battery of my car 6 months ago with Advanced 019 AGM Car Battery 95ah 900cca with 5yr Warranty. I think the original was 70Ah.
For the last 2 days since weather has turned colder, the error message "Convenience features not available" has been showing up for the first 4-5 miles of the journey.
The battery voltage in the IPC before crank is 11.5V. After the car starts, the voltage is 13.8V and subsequently 14.0V when the convenience features are available again.
Am I right in thinking that this may be caused by the aux battery which is probably as old as the car or could it be Faulty Isolation Relay draining the main battery?
I am probably going to keep the car for another year max, so can I replace the aux with a Motorbike Gel Battery with same spec/ dimensions like this:
ULTRAMAX YTX14-BS, 12V 12AH 180 CCA MOTORCYCLE, MOTORBIKE, QUAD BIKE, JET SKI
Thanks for your help in advance.
