S211 Command with phone pre-wire
MattEly
Berkshire
E320 CDI Estate S211
Hi Guys
Quick question - I have the pre-wired phone & Command which I use with the Nokia 6310i. The Nokia phone allows you to store multiple numbers against each name, whilst Command only seems to allow you to select the "default number" - however, incoming calls from "non-default" numbers are recognised and the caller's name is displayed. Is there any way in which you can call up the non-default numbers through Command?
Cheers
Matt
