s211 e320 cdi OM648.961 2003 Engine Mounts
merc85
Harwich
CLK 500
On the above car, thinking about changing the engine mounts as they have done 90k, done a little research on here and over on the Usa forum.
Some have said when doing the osf engine mount you have to unbolt the bracket from the engine that the mount is bolted to.
Other's say you can get the mount out without doing so, Also same say remove the alternator some say you dont have to.
Does anyone know the answer's to the above for sure? this is a om648 straight 6 engine.
Any help much appreciated.:thumb:
