S211 Fuses and relays
Discussion in 'Engine' started by AntMB, Feb 11, 2019.
  1. AntMB
    AntMB Hardcore MB Enthusiast
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    Mercedes E270 Estate and VW Golf
    Does anyone know or have a good map of the fuses and relays? I have the handbook for the car which is not helpful with identifying fuses and relays.
    I've searched online but I only get photos of fuse boxes rather than a good layout/map of them detailing the number of each and what each is for.
    Thanks.
  2. merc85
    merc85 MB Club Veteran
    7,131
    Apr 23, 2013
    Harwich
    Car:
    s211 e55k
    There's usually a sheet of paper charting all the above situated in the Fuse box End of the Dash Drver's side Pull the cover off to expose.
  3. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    I have that sheet but it doesn't appear to detail relays.
  4. Salal
    Salal Active Member
    76
    Oct 5, 2014
    London
    Car:
    W211 E320cdi Estate, W210 E200K, W209 CLK220. Previous:W203,W202 & Smart W451
    I can get it for you from the WIS (workshop manuals). If I remember they are well detailed on there. Il look it up when I get home.
  5. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
  6. Salal
    Salal Active Member
    76
    Oct 5, 2014
    London
    Car:
    What year is your S211, there’s two configs depending if your car is a facelift or not.
    Either up to 31.05.2006
    Or as of 01.06.2006
  7. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    2003, would my VIN be of any help?
  8. AMGeed
    AMGeed MB Club Veteran
    11,055
    Nov 1, 2008
    Bournemouth/Poole Dorset
    Car:
    2004 W211 E55K ///AMG
    This is a diagram of the relays inside the drivers side engine bay fuse box. I have some others if you can be more specific which ones you need.
  9. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    Hmm, thanks for the info, though that layout doesn't appear to look like what's under my bonnet.
  10. Salal
    Salal Active Member
    76
    Oct 5, 2014
    London
    Car:
    Ive uploaded the pdf versions, the engine comparment is the same I've uploaded, are you sure its not the same?
  11. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    It does look different. I'm trying to identify this relay pointed to. The lay out looks different, to me it's too different for me to identify the items. Confusing a little (to me).
    [​IMG]
  12. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    Thanks for the uploads. On the sheet titled 'fuse and relay box general locations', where exactly will I find the fuse boxes which point to the bulkhead for F32 and the passenger door for F34?
    Thanks.
  13. Salal
    Salal Active Member
    76
    Oct 5, 2014
    London
    Car:
    It is the same, the one on the manual shows everything fitted, but you may not have every option hence you may have some relays or fuses missing
    What it looks like your pointing to is Relay I.
  14. Salal
    Salal Active Member
    76
    Oct 5, 2014
    London
    Car:
    If you open your driver door, on the side of the dashboard where the door covers that section there’s a flat panel there, it will be behind there. There’s a small seration you can pry it open with, there’s two retaining clips and they can be quite tight. Use maybe a plastic tool or something to prevent any damage.
  15. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    Yes I think it is relay I. I'm wondering what exactly it does, it's possible this one may one I need to pay attention to. Thanks for the information so far.
  16. Salal
    Salal Active Member
    76
    Oct 5, 2014
    London
    Car:
    What problems are you experiencing or trying to trouble shoot?
    Not sure what terminal 87 on relay I supplies exactly, will need to look at the wiring diagrams to figure that out. Might be a 12V feed to the ECU which is N10/1KL I think.
  17. OP
    OP
    AntMB
    296
    Nov 22, 2018
    Oxfordshire
    Car:
    This one
    Broken down, help, urgent
  18. Ted
    Ted MB Club Veteran
    5,514
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    87 is switched live (low current)
    Probably from ignition.
Share This Page
