Borris1954
- Feb 4, 2013
- Location
- South Bucks
- S204 C 250 CGI BlueEFFICIENCY, R170 SLK 230, B 180d AMG Line
My 2006 (facelift) S211 E Class Estate has the power lift (option code 890). This has worked great until this last weekend when after a heavy frost the tailgate stopped several times on opening and also on closing. I had hoped this was just some frozen water in the hinges or other bits of the mechanism (after I finally gave it an overdue wash) and the problem would clear as the day warmed up. It didn't! So I did some research and found lots of posts about the hinges partially seizing causing similar issues so today I removed the left and right hinge covers and lubricated the hinges with some graphite oil and also some PTFE lubricant. This seems to have has loosened things up nicely. BUT now on opening the tailgate always stops at around the mid position. Operating the rear handle, pressing the key fob or the internal opening button on the drivers door will raise the tailgate fully. I could just about live with this but a bigger issue is that pressing the button on the tailgate to close it (there is no key fob or internal button for closing) does nothing at all.
I am fortunate to have access to a Star Diagnostic System (SDS) and a scan reveals that there are no fault codes (just a stored event for low voltage at the control module at some point in the past). However, the actual values show the door status as not "Normalised" which sort of makes sense given the symptoms. I can quite believe the stop start behaviour might have mucked up its normalisation. Using SDS to normalise the door doesn't really help me as the process requires that you be able to power close the door from its fully open position which I can't do.
If anyone has seen this before or got any bright ideas I'd be grateful for any advice. It just seems very odd to have no fault codes present with quite a blatant fault unless I am just missing the point on how to normalise the door.
