S211 riding low
Oakesy2001uk
Cheshire
2007 e320 estate
My lovely s211 estate (07) is sitting a little low on the back. A friend plugged it i to his scanner in and it said -10 on rear ride height. If you load the rear up it takes it back to the same level (still low) so its working, just not sitting at the right level.... drives ok, no warnings on the dash in 5000 miles I’ve had it.
Always been like this for the 6 months I’ve had it, didn't think much of it but its worn the rear tyres outside in in 5000 miles.
Hoping its just a case of moving a sensor or something, is this common?
I’ve got access to a ramp and will also do an aligment due to the tyre wear, but think ride height also must be a factor. not got star, just a good generic scanner.
You can re-level it using star diagnosis on a flat surface. If this goes down again it means your pump is dying
Sent from my J8110 using Tapatalk
