S212 brakes sport vs “normal”?
ChrisHGTV
Guildford
E250 Avantgarde Estate, Alfa GTV V6, Vespa, Ducati, many bicycles...
Hello all
The blue barge is now calling for front pads, and the discs I think need doing as well. There is a lip of a good 1mm. I’ve got some prices from MB Newcastle etc but then saw GSF have Brembo discs for £69 which seems a bit of a bargain. They have the cross drilled ones as well as the standard and both seem to be identical in size.
So I was then thinking genuine pads with the Brembo discs (Cross drilled or standard)
Or is it safer to just get the standard kit from MB Newcastle for £222 which is about £60 more?
Any thoughts? I’m overthinking this as usual and being seduced by those cross drilled discs! 🙄
I would think that a 1mm lip would be nowhere near the wear limit.....
Possibly not exactly the same, but in my E350 brake thread, the front Brembos are 32mm wide, with a minimum thickness of 30mm
I think they’re the same size on mine. What I can’t work out is whether the cross drilled discs for the Soorts package brakes are the same/compatible with the standard. All the dimensions seem the same. The cross drilled are now £59 on GSF!
