bengal1957
- Aug 29, 2017
Hi all
I have been having an ongoing problem with EML coming on with fault code P2459.
I clear the fault and it is fine for a while.
After a long run (which I do on a daily basis) I will stop for a short while then start up again. Normally at this point I notice the revs are holding in at low speed i.e. Not changing up, that's when the light comes on.
In the past 2 years it has had 2 nox and 1 DPF Sensor replaced!
My Indi has had it on the Diagnostics machine and it is saying it is regenerating too frequently.
Any thoughts or previous experience to remedy this would be much appreciated.
The year of car is 2011
Many thanks
Many thanks
