dougdotcom
- May 29, 2015
- mercedes s430
Hello everyone, im new on here with a car i just got that had central locking problems, the pump would spin ok then start to run very slow, i brought a replacement complete unit with identical matching code numbers,
We marked the air pipes so not to get them mixed up on reconnection, but sadly after we connected back up things did not go as expected, the soft close did not operate, some of the doors locked then would not unlock, im thinking that as the last owner had took the air box apart he also removed the pipes so must have just re fitted the pipes in a way not correct to make correct operation and we have marked them and re fitted them the same way, is there a way to know which pipe fits where?
I think if the door locks are opening then they must be able to close too via the same air pipe as we pressed the lock and unlock and the air blows and sucks out the same connector on the air box so is it just one outlet on the air box for all four door locks? im so confused im used to electric door locks no air, so dose anyone have a system to help me get the right pipe onto the right outlet of the air box? thanks everyone.
Ps.. if you notice this photo was taken of the air box that was faulty and with the pipes as he left them, if you look closely you can see the top right pipe is not even plugged in as it dose not fit, the socket is too big for the pipe to connect to it, so where dose that one go?
