Hello
So, I am getting a roaring noise when braking from high speed. It sounds just like a broken wheel bearing. The noise comes from the front of the car.
When I stop braking and let the car slow down on its own, the noise goes away.
So I replaced several parts but was not successful at solving this issue. I replaced:
- Wheel bearings
- Tires
- balanced tires + performed wheel alignment
- Brake discs + pads
- Brake calipers
Small video I made. Starts braking at 5 seconds. You may need to use earphones to hear the noise.
Would be great if I could get some help.
Thanks!!
Jake
- Wheel bearings
- Tires
- Brake calipers
Thanks!!
Jake
