robgosty
Hi all, back again for more advice, 97 S500 5 litre, undone bolt on top of oil filter housing, bolt will not pull through top cover (or lid) if i try to remove bolt and lid togeather there is not enough clearance, it hits on chassis rail, how the hell do i get it off ?? do you just jack engine up a bit to gain space
or are my engine mountings shot, hence engine sitting lower than it should be
any help much appreciated as filter change well over due
Cheers, Robin
Cheers, Robin
