Some weeks ago the horn stopped working. I have checked and double checked fuses relays and cables. So took it in the my local garage. They did some investigation works and think it might be the SAM module. The car is a WDD204.
Has anyone had a replacement fitted and not had to have it coded as I seen stuff on the WWW and it looks confusing. Also is the SAM located under or next to the fuse/relay housing? Thanks
