Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
Did you bother reading the article from Autospeed, they are easily able to make a hand operated stopwatch within 1/10th of a second and having just tried it myself find it works fine.Re-read my post... It clearly says hand timed stop watch.
As to dieselman... Where are you getting your facts from that a hand operated stopwatch is accurate to 1/10th of a second. There is no consistency to your method. Fair enough if you were doing it on a completely straight road with an automated timing system (santapod). But using a hand operated stop watch... What rubbish!
I just timed 15, 5-second intervals, without really concentrating. The worst error was the first go and that was 0.17 of a second out of the average. Three others were 0.11 seconds out and all the rest were well within 1/10th of the avearge.
0.17
0.01
-0.01
-0.08
-0.08
-0.07
0.11
-0.02
0.11
0.08
-0.07
-0.05
-0.11
0.05
-0.02
You don't need to know an exact time, you need a repeatable average.
While searching the other night I found a thread where some guys are tuning their cars and testing on the road over a measured 1/4 mile. they then went to the Pod and were within 1/10th sec of their times.
Thread..
http://www.fiatforum.com/marea/124445-jtd105-performance-testing-0-60-0-100-a.html
Post..
http://www.fiatforum.com/marea/124445-jtd105-performance-testing-0-60-0-100-a-2.html
Also, you seem to have little faith in your abilities to time your car with a reasonable (to less than half a second) degree of accuracy. We timed my friend's car several times with a stopwatch on our accurately measured quarter mile, and found it to be right within a tenth of a second when he did an rwyb at santa pod.
I can't understand why you have a problem with that, a stopwatch is an exact timing device, sure it's not as sexy as a dyno chart, but it tells you a lot about on the road performance.
Remember, you don't need an exact figure..just repeatability... An inertia wheel dyno won't give you an exact figure either, just a calculated assessed figure.
Take you car to two dynos and it will read differently, take it to the same dyno two days running and it will read differently.
Seriously.
For the Guys getting your cars chipped/tuned do some stopwatch runs before and after and post the results.
It will cost the cost of a few runs up and down a straight road and a bit of time...i.e. nothing.
I just tried the stopwatch again but using my thumb instead of fore-finger. I got all bar 2 of the times within 1/10th second of each other, so the spread against average is now much tighter.
