All,
Drove the car out of London on the A24 down to Little Hampton. On the way there and back had alot of problem with Sat nav/Command. It would be working then suddenly cut off and the sysetm would tell me that it could not locate a signal on the digitized map. The CD and radio worked fine but the sat nav just stayed off line.
I removed the disk from the unit,switched it off and re booted it then insert the nav disk again. The Sat Nav was ok for about 5 mins then it went off line again.
The disk I have is a 2000-2001 version so its quite old, dont know if it could be the disk?
Can anyone help me with this problem is, any help is appreciated.
