Hello all. I have a comand ntg 2.5 sat nav. What do I need to update the maps? Cheers Matt.
Ok thanks for the reply. How much you after for the dvds. Cheers.Latest version is 2019 part number A219 827 27 00 and is also the last update which MB will issue for NTG2.5 (which is what I have in my SLK). It requires NTG update 09/29 which if you're lucky will already have been installed. Fortunately if it's not installed and you try to run DVD1 of this set, it tells you "update cannot be installed" rather than bricking your system. Despite my 2008 SLK having been serviced by the supplying MB main dealer for the first 5-6 years of its life, this update had not been installed (which is how, with the help of comand.co.uk, I found out about "update cannot be installed") so as I was taking both cars to them for a lot of stuff on the S204, they updated to SLK while we waited (at a cost, of course) and I then installed the map update myself.
I have the update DVD's (genuine MB) surplus to requirements if you're interested (I bought them "second user" off Ebay
