This is my first post so be gentle, thanks.
I have purchased a Mecedes e class 250 cdi sport 2011. I would like to upgrade the stereo from an Audio 20 to Comand NTG4.0, this is the model that will fit my. I have a number of questions and would be greatful if some one could help.
Is the Comand NTG4.5 compatiable with my car and a staifght forward fit or should I stick with the Comand NTG4.0 since it is 100% compatible.
If i was to purchase a NTG 4.0 from ebay does any know a descent comapny that can install it and program the cluster via star and the stereo. Also would I require the following ducting kit supplied by command or can I just upgrade.
Retrofit Kit for COMAND NTG4 in W212 E Class - Right Hand Drive | W204 C & GLK Class, W212 new E class, W207 E class coupe | COMAND Retrofit parts | Mercedes Retrofits | Comand Online Ltd
The kit consists of instructions and all parts needed expect the display and COMAND unit and the GPS antenna. - These include the fan ducting, fan and wiring looms, and antenna adapter.
Please do not "skip" the fan installation, the unit will overheat in warm weather and cause damage to itself and possibly your car.
Does any one have any guides on the process of upgrading Audio20 to command ntg 4.0 for mercedes e class w212. Is the process of upgrading the screen involve removing the dash or not.
I have googled the following three companies are they any good with installs and would they use the ducting kit - they charge around £900 for install, has any one used
Mercedes Navigation
OEM Retrofits - Mercedes Sat Nav Systems - Comand, Command, NTG 2.0, 2.5, 4.0
Mercedes Navigation | Mercedes Retrofit Specialist | Comand Navigation, Mercedes Reverse Camera, Mercedes Heated Seats, Mercedes Bluetooth Kit, Mercedes IPod kits.]
Finally the above companies also install the rear camera in the car is there a lot of work involved with this. I am worried in case the job is not too great. Any suggestions welcome, I live in London.
Mercedes Navigation
