Satnav/GPS way out
Discussion in 'Electronics' started by omega1, Feb 9, 2019 at 4:10 PM.
  1. omega1
    omega1 Hardcore MB Enthusiast
    277
    May 11, 2009
    Hampshire
    Car:
    E350d 2017 (W213)
    Hi all,
    Recently the GPS location on the satnav is way off, putting me in Germany most of the time, though it is completely random.
    Is there a reset or anything I can do, or does it need to go back to MB?
    It's a E350d W213 2017 with the split screen, half digital half analogue, not sure if that makes sense. Not sure what version or anything like that.
    Any ideas?
    Thanks.
  2. whitenemesis
    whitenemesis MB Club Veteran
    14,849
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2016
    Take it to MB, it's still under warranty...
  3. richard
    richard Authorised Forum Sponsor Authorised Forum Sponsor
    5,870
    Jun 10, 2002
    Berkshire, UK
    Car:
    MY04 SL55, MY17 GLC250d AMG Sport
    As per whitenemesis although just unplug any chargers or similar you have plugged in incase they are causing interference with the GPS antenna - although I suspect there is an issue with the GPS antenna.
    R
    Gbrowncls55 likes this.
  4. OP
    OP
    omega1
    277
    May 11, 2009
    Hampshire
    Car:
    E350d 2017 (W213)
    Ok, thanks, was just wondering if there was a ''reset" I could do somewhere, sometimes my phone does the same thing and if I turn it off and on again it fixes it.
    I'll take it back in. Annoying as it's just come back out due to a steering "squeak"...
    Cheers.
  5. OP
    OP
    omega1
    277
    May 11, 2009
    Hampshire
    Car:
    E350d 2017 (W213)
    Strange, it works OK again now... I'll leave it and see what happens over a few weeks and take it back if it re-occurs.
  6. Diesel Benz
    Diesel Benz Hardcore MB Enthusiast
    4,039
    Feb 3, 2006
    Europe
    Car:
    222.132 & 221.122 & 213.050 & 906.633
    It must be a broken GPS antenna. They all fail on the W213, at least up to MY 2017, haven't checked if the antenna part has changed recently. Wife's (MY 2017) car failed a year ago. It came back a few times before the antenna was changed under warranty. A proper workshop should see the issue from fault codes (refer to TIPS) even if the antenna happened to work at the workshop inspection.
Share This Page
