Any joy resolving this issue??
I have a 2016 W205 C class AMG Line Premium Plus with comand NTG5.2 which is suddenly having issues with GPS location and navigation issues.
The vehicle position is drifting off slightly relative to map roads etc. by enough that if following a route, it displays "road not mapped", and the nav system attempts to re-route.
The vehicle direction pointer is facing upwards, (with the direction of travel orientation set to upwards, not north) but the maps are scrolling horizontally left/right with the direction arrow at about 90 degress to the direction of travel according to the map.
The map and road should normally rotate so that the road is always vertical and in line with the vertica direction arrow.
The compass appears to be out by about 90 degress.
The system show 9 or so satalites found, so in theory enough for a good fix (although this does not guarantee the signal as processed is accurate)
There are no fault codes regarding the system or gps receiver etc. and the hermes module shows 38dbuv gps signal strength.
The maps are the latest version 15, updated July 2023.
I have ordered a replacement GPS antenna, but not confident that this will cure the issues.
So, interested in hearing any similar experiences/fixes, as there are not any definitive answers from my searches.
