satnav
georgebro
west lothian scotland
merdedes e320 cdi estate
fitted a new gps aerial to my car but still shows me in the north sea of berwick upon tweed is there something else i can do
Remove fuse for Comand / nav processor to reset unit fully or remove the power cables from the back of the units. Have you checked how many satellites comand says it has picked up after changing gps aerial?
It will be in one of the menus when in sat nav mode, your Comand user manual will tell you how to check.
On Comand 2 devices you can check the number of satellites on the Map screen. When not navigating just press the 'Map' button and it should show your latitude, longitude and how many satellites it has locked onto.
