Im aware i have an SBC fault and need to get it reset etc. As im getting the service brake visit workshop message, everything else checks out, new discs pads wear sensors brake switch etc.
As soon as i unlock the car it activates the sbc and it moo`s like a cow, 7 times out of 10 as im pulling away slowly its locking up the front near side wheel ONLY and slows the car down while pulling the car to the left, while its doing this the yellow ESP triangle flashes on the dash and then the ESP defective warning comes up. It does it for a few seconds then its fine, doesnt do it all again until i stop and switch off then restart etc. Im also aware that my SAS (Steering Angle Sensor) could be faulty.
Sometime after i start the car it doesnt do it, no ESP fault and the cruise control works fine suggesting an intermittent fault.
Any ideas? Will an SBC reset clear this? is it the SAS causing it all? could the wheel speed sensor on that corner be faulty? Im not getting any ABS faults
Thanks in advance
Thanks in advance
