TennesseeJack
I have all of a sudden the dreaded red light on my dash and left with reduced braking power only while out driving this week, luckily I was only doing about 10MPH at the time it happened. Being less than a mile from home I managed to get back ok.
The car in Question is an SL350 and is ten years old and is just approaching 40K miles.
I have checked the brake fluid and the level (recently serviced) is just above the maximum, I also have an ICARSOFT scanner i980 that I have used before on the car to check codes and it has read the following codes
C25D4 no pressure
C26EF Test voltage supply (circuit 30) of component A7/3m1 (high pressure charge pump)
C233D, C22BC, C23BD, C223C no pressure at wheel.
I am assuming I will need a new SBC pump? or have the faulty one repaired?
can anyone recommend a company to refurbish the SBC pump?
I would be grateful for any advice or help on this matter.
Kind Regards
C25D4 no pressure
Kind Regards
