Probably hard to remove the scratching as the wood veneer is very thin - its mainly solid wood and metal.
You could cover the entire panel with some dark walnut film (see www.foliatec.de) which is a pretty good match - otherwise replacing these panels from the dealer is very expensive. £100-£200 per panel - or you could try a breaker.
