Screen upgrade
Kaml
Canada
Cla 250
I have 2014 Cla 250 Audio 20 without navigation small screen and i have another screen came out of 2017 cla, i tried to install that but the screen remains black
Is there any solution so that it will work?
The other car with the larger screen had COMAND, which is a higher-end unit than the Audio20 fitted to your car.
I don't think that a COMAND screen can work with Audio20.
You may be able however to swap both the infotainment unit and the larger screen from the other car, and they will work as a set.
You may however need some wiring and adapters (and possibly also STAR config) to get COMAND to work in your car.
www.comandonline.co.uk should be able to provide the wiring and adapters required, and also the additional cooling fans (if needed).
Ah... right :D
