Hillbillybenz
Hi all, after finding a few hints on carrying out this repair I though I would take a few pics as I went to help others. As Im usually useless at diy stuff like this I figured this thread would give others like me confidence to carry out what is a very simple job to rectify what must be a common issue. Both seats in my CLS where damaged the same way.
This below is the damage to the top clip retaining the pocket
Remove two screws under with hex bit
Seat back will then slide down after removing adjuster handle below 2nd pic
Again held in place with hex screw behind rubber grommet
I used a self tapping 8mm head screw that had a built in washer, I screwed this into the back of the broken plastic rivet
Rebuild in reverse and job done!
Not an epic win but for a man who usually works with big hammers and trowels it made my weekend and prob saved me a few quid on replacement bits
