Seat belt butlers not working
Discussion in 'Interior' started by Makdissy, Jan 31, 2016.
  1. Makdissy
    Makdissy Active Member
    80
    Nov 23, 2014
    Staffordshire
    Car:
    Mercedes 320ce
    Hey guys, my w124 320ce butlers not working at all, ( no sign of life) is there a common fault???? Where do I start looking ???? :confused:
    Peter
  2. tintinmt
    tintinmt Hardcore MB Enthusiast
    364
    Feb 1, 2009
    There are common faults. Are both not working? If so, maybe start with the controller unit under the rear seat. They can suffer from water ingress. If it's just one that's failed it may be stripped gears in the presenter mechanism or possibly the micro switches on the arm. These can be checked by removing the side trim panel in the rear of the car.
  3. richard
    richard Authorised Forum Sponsor Authorised Forum Sponsor
    6,167
    Jun 10, 2002
    Berkshire, UK
    Car:
    MY04 SL55, MY18 GLC63s
    Id start by removing fuse , cleaning the metal bits and re-inserting in case contacts have become dirty (as both stopped, I think its one fuse)
    Richard
  4. OP
    OP
    Makdissy
    80
    Nov 23, 2014
    Staffordshire
    Car:
    Mercedes 320ce
    Well, I'm not quite sure if both of them had stopped at the same time as I bought the car like that, but the question is if there is some thing wrong with gears or other parts are they repairable ???? Or you have to replace the whole thing???
    Peter
  5. tintinmt
    364
    Feb 1, 2009
    Hi, Is yours the cabrio? If so, they have different presenters to the coupes. The fact that both are not working would make me start diagnosis of the common parts (like the controller). It is possible to make repairs to the mechanisms. The driving force is the cost of replacement with new presenters as MB don't offer spares.
    I seem to remember that once I got to the controller under the rear seat it was obvious when opened that it was scrap and a replacement was part of getting both presenters fully working again. On that note, you could well find that there is more than one issue to cure!
  6. OP
    OP
    Makdissy
    80
    Nov 23, 2014
    Staffordshire
    Car:
    Mercedes 320ce
    Is this what you talking about???
    On the right hand side as you are facing the back bench???
  7. OP
    OP
    Makdissy
    80
    Nov 23, 2014
    Staffordshire
    Car:
    Mercedes 320ce
    Can someone tell me what is this???? ( Becker ) !!!!!
    It's on the left hand side under the bench as you are facing it
  8. Benzmanc
    Benzmanc Hardcore MB Enthusiast
    1,748
    May 22, 2011
    Tameside
    Car:
    Tesla Model 3 + Honda Blackbird
    Your first pic is the window relay control box and second is for the roof - google the part numbers.....
  9. tintinmt
    364
    Feb 1, 2009
    I have just remembered...
    It is not unheard of for owners to intentionally
    disconnect the system when the gears start grinding.
Share This Page
