seat belt for 6th and 7th seats please
michaelk3289
London
1999 W210 E240 Avantgarde
hi there i need a driver side seat belt for the extra 2 seats in the boot. i had two supplied with the extra seats but one locked up and try as i might i could not get it working
i need the complete seat belt with roof mounting
thanks
Michael
bolide
Brighton
BMW E39 525 Diesel Touring
If it has locked up it's probably the wrong belt. There are X, Y and Z-axis indicators on the belt mechanism showing the correct orientation of the reel. If the orientation is wrong it won't function
If it's right, and still won't function, try getting the belt to retract a bit before pulling it out again
Nick Froome
the independent Mercedes Estate specialists
OP
OP
M
michaelk3289
London
Nick Froome
i tried holding up the correct way as well as trying to get it to retract, it was just wound up way to tight and wouldnt budge in either direction,
thanks for your info though
SilverSaloon
1994 W124 E300D Estate, 1985 R107 280SL
try fitting it in its installed position and then try - when i removed the 7 seats (and other belts) i noticed just a few degrees out from the installed position it wouldnt budge..... magically if the angle is spot on then it worked.
once its in position, try pulling it out VERY slowly - it should unreel.
good luck !
