Hi All,
Before proceeding ahead with this work, I would appreciate some advice here.
I have a C220 W204 which had its A service today. I have been advised by the specialist that there is additional work which also needs doing in order to pass its MOT.
- Due to corrosion, its required the front near side brake pipes needs replacing
-Due to corrosion, the nearside brake and offside pipes and brake lines need replacing
-Post the brake pipe repair and the bleeding of the brake system yo be carried out
-Remove and refit of the rear centre seat belt
-Full DPF regen required due to DPF fault and O2 sensor fault picked up by mercedes xentry diagnostics.
All the comes up to around £1500. Can anyone confirm if this about right for the above listed work please?
Is this roughly in line with what I should be paying? Just want to ensure this is all in line as to what I should expect
Many thanks
KD
Many thanks
KD
