ollieplimsoles
- Mar 2, 2006
- Location
- BELFAST
- 1991 Passat TDi 130 Hiline, 1991 Mercedes 190E 2.0 Auto, 1984 Mercedes 500sec, 1991 Saab 900s LPT
Had a little problem with my 1991 190E 2.0 auto. The fan wasn't working correctly and the car overheated resulting in a destroyed thermostat housing cover and coolant everywhere. Replaced housing cover and thermostat and re-filled the cooling system.
Now.. the car has been sitting a while and of course the battery has gone flat - so I replaced this with a new one and... the car would not start. Solved this when I discovered a spade connection had come off some aspect of the after market alarm/central locking kit.
The car then started and I took it for a run - perfect at speed, no sign of overheating - rather rough at idle and a tad reluctant to start while warm.
Next day - the car will not start. Starter motor fine it just doesn't seem to want to fire - almost like the immobiliser is active - I can detect the slightest hiccup during cranking. Furthermore, I have discovered an unattached sensor and I cannot locate where it should go. It would be too good to be true if this were the problem but I have attached some pics to see if anyone can identify it! Does it connect to the distributor itself?
Regards,
Mark S.
Regards,
Mark S.
