Good evening,
I appreciate your elp with my first post, not I have another.
I have purchased a code reader with live data, a couple of things.
I have very poor MPG consumption, and wondered if you could provide some guidance on what to do. Many thanks
- My coolant temp never gets above 58 degrees, - would this be a temp sensor issue or a thermostat?
- My catalyst temperatures are stuck even from engine start at senor 1 minus 40 degrees and sensor 2 2203 degrees, these figures never change.
- EGR error is 99.219% with a command EGR 4.706%
- The air flow from MAF at idle Is 13.3g/s
