Pavz
Hi all,
Looks like I have some serious problem with my car (CLS63 2015 AMG S) and I'm looking for some advice here.
I think there are two different problems but can't say for sure.
First one is the engine check light on the dash. This were reset couple weeks ago by MB dealer by soft update to the throttle bodies (that's what I have been told). Light came back again after few days so I assume the problem is different and must be investigated further and another software update/reset will hot help. The error code related is:
P217616 - Adaptation of the idle position of the throttle calve actuator was not performed. The limit value for the electrical coltage has not been attained.
At that time I also had few Collision prevention Assist Plus inoperative messages on the dash screen, but those were always disappearing few seconds after.
I left the car with the dealer and they updated the software. Problem came back few days later.
With above engine check light car was running just fine, all the power and torque were there and beside the light on the dash - it was drivable.
On the top of the above, after next few days things get worse.
During the drive I started to receive a lot of messages and few different lights started to come up and dissapers frequently.
When I start the car sometimes I can drive for several miles without any problems (except above engine check light which is always there), but sometimes those messages and lights coming back few seconds after I start the engine.
Here are all of them:
- Collision Prevention Assist Plus inoperative
- PRE-SAFE inoperative
- Traction Control inoperative
- Traction Control and ABS inoperative
Above messages coming in conjuction with several lighs:
- Traction Control OFF (yellow) (on the fuel level/temp gauge)
- Traction Control (yellow) on the rev gauge
- ABS (yellow) on the rev gauge
- Brake light with exclamation mark (red) on the rev gauge (this is not for hand brake applied this time)
Sometimes it just switches TC off (both yellow TC lights are on, ABS and red Brake light are extinguish) and car is still drivable.
Sometimes all above are on and then car goes in to "safe mode":
- cannot exceed (about) 1500rpm therefore only low speed drive possible
- I can feel turning steering wheel becomes harder, so it affects power steering as well
- speedometer needle drops to zero - doesn't show current speed at all
- at this stage I was having a problem to turn ignition off, normal start/stop button press didn't work, I had to press and hold button for several seconds to turn the engine and ignition off. This happend only once so far as previously car was getting into safe mode only during the drive for very short period of time and it was coming back again. I could see speedo needle going down to zero and in next second or two go up again to the speed I was driving. I think when this was happening also ABS and red Brake light with exclamation mark were also coming on the dash for this short period of time and dissapear as soon as the speedo go back to the right speed). Only once so far it stayed in safe mode until I completely stopped the car and then I discovered I cannot turn it off easily.
I'm devastated as I suspect this will not be easy to fix and my holiday coming in next three weeks ;/ and I can't drive this car with the above problems across the Europe.
Maybe some of you guys had similar problems and could point to what could be the potential issue. I will highly appreciate any help. I'm thinking to leave my car with ACMS Birmingham for investigation as my experience with MB dealer is not best so far - they seems to be not too interested to investigate what the problem is and trying to get rid of me as quick as possible. This is my first Merc and such a disaster - serious car issues plus not best dealer service experience ;(
