24karrat
- Jul 19, 2013
- Location
- West Midlands
- 1989 560 SEL AMG Japanese Import | 2014 A180 CDI AMG SPORT
Will shells v power fuel make any difference to a 560 sel?
If the extra costs are not a problem, then definitely worth using V-power in that engine...it deserves it . Plus it will help keep the engine clean and give a longer life to specific components, in the long term. That fuel is really beneficial in terms of engineering aspects but most of us might not notice its benefits physically... Wern't these engines originally designed to operate on leaded fuel... 4 star etc etc? It would be interesting to see how these engines behave with unleaded fuel...or is there no difference?
The German cars are OK with respect to unleaded fuel BUT there is an
emerging problem for us older car enthusiasts; bio fuel.
Tests show that older engine fuel systems are being adversely affected by the introduction of bio fuel.
It is causing internal corrosion and the breakdown of seals etc.
I have therefore switched to using super grade fuel in my 95 car, because the petrol companies have not (as yet anyway) introduced the bio additives into these more expensive fuels.
An alternative would be conversion to LPG, as again the German cars have strong engine valves which will stand the test of time, and of course you will benefit from lower emissions than both petrol and diesel, which may benefit you now that authorities are looking to add an extra layer of tax to the more polluting cars, with a ban on city centre use.
It looks as if diesel drivers may be in for a big shock in this latest scenario.
The main reason I use Shell V-Power is because it is supposed to be a lot better for your engine.
Performance increases are always welcome but having as clean an engine as possible is my other main priority.
jaymanek said:Its very simple. Cars that are tuned for higher octane fuels will do better on super. Ones that are not, you are just wasting money. Some older cars were designed to run on 97 at least but majority are tuned for 95 Ron and will run happily on 93 or even 91 in countries where its not available. On the 560 M117 there are no sensors to adjust for the higher octane fuel and you are just wasting money. On my SL60 for example, it states we should use 97 wherever possible and so I use it. Same for my 190E Cosworth. The 500E M119 uses normal... The 300TE AMG uses Super... Basically use what it says to use on your fuel door!
24karrat said:13 strong! thats a fortunate predicament to be in, the sec wide body in your profile picture looks a absolute stunner, i don't have kids yet so in my case it would be trainers lol when do you find time to drive them all or do you alternate to keep mileage to a minimum?
