Have searched the forums, but don't find anything similar. So help me out here.
When coming to a standstill, the trans shifts into first gear really late ie. at a speed that is almost near or at stop, which results in a slight surge just before stopping. Similar to if you would mildly jab the accelerator before stopping.
I tried in W mode and this does not happen. I figure cause in W it does not shift down to 1st.
Also, manually shifted (through the touch shift) into first at a slightly higher speed (15kmph) and this surge did not happen.
Have recently (3000km ago) changed the trans ATF and trans filter alongwith the engine oil and filter.
Where do I start?
Thanks in advance.
Where do I start?
Thanks in advance.
