Guys, I heard a knocking sound from the front nearside and when I investigated, the rubber stop that sits on the shock has almost disintegrated. This is the stop that is on the shock but within the wheel compartment not on the top where it feeds through and into the engine bay.
I assume it was due to bad fitting by the mechanic when the shocks were fitted a few months ago.
However, assuming I can get a rubber stop tomorrow, how easy is it to fit bearing in mind I need to pull the shock back down into the wheel compartment to get it on and then feed the top of the shock back up and into the engine bay?
Do I need to get a garage to do it?
Cheers guys.
Cheers guys.
